I just ordered a cigarette lighter from Classic Parts for my 66 pickup. Is it pretty apparent where the connections go or does it come with instructions??? Also, is the output ok for charging cellphones, Ipod etc.
RE: Installing a Cigarette Lightrer YOU CAN ACTUALLY WIRE IT TO A HOT LEAD FOR CONSTANT POWER, OR YOU CAN WIRE IT TO THE IGNITION TO ONLY GIVE IT POWER WHEN THE KEY IS ON. YOU CAN USE IT TO CHARGE YOUR CELL PHONE AND OTHER EXCESORIES LIKE A LITTLE AIR COMPESSOR, SPOT LIGHT, WHATEVER RUNS OFF A CIGERETTE LIGHTER. GOOD LUCK. 66 KUSTOM
RE: Installing a Cigarette Lightrer I do belive that it is marked on the fuse box right where it goes. Don't worry the lighter will handle just as much juice as a new vehicle.
RE: Installing a Cigarette Lightrer >I do belive that it is marked on the fuse box right where it >goes. Don't worry the lighter will handle just as much juice >as a new vehicle. Thanks much for the advice.
RE: Installing a Cigarette Lightrer thanks to both you guys for the reply's. It sounds like i can figure it out.
