Instrument cluster lights
Discussion in '1955-1959' started by garrison, Nov 20, 2016.
  1. garrison
    garrison Member
    How exactly do I simply replace the dash bulbs for the instrument cluster? Do I have to unhook everything and remove the entire cluster or is there a way to get to things and avoid that?
    57 pickup
  2. AZ58Cameo
    AZ58Cameo Member
    Payson Arizona
    All you need to do is pull the cluster out away from dash and remove the bell shaped metal housings that have the bulb in them, pretty easy!
    also i found that on some of my new ones they would not stay in place even after trying to pull the tabs out on them to make them a little more stiff, so what i ended up doing
    was installing the housing in place and using a small dab of hot melt glue and that kept them in place, and if you need to replace the bulb you can just scrape away the clear glue and replace.
    FWIW
    Allen
