It worked
Discussion in '1947-1954' started by coilover, Sep 8, 2012.
  1. coilover
    On gas tanks that are too caked up to clean by tumbling and are way beyond being boiled clean by a radiator shop I usually cut an access hole in the top and sandblast the crud/rust out and then take them to the radiator shop for cooking and sealing. The access hole is patched back in first. The problem with the blasting is you can get the sides and bottom very well but on a shallow tank you can't bend the hose and nozzle around to get the underside of the top and it's usually the worst. You know how when pressure washing an engine with uneven surfaces the water will get blown back in your face? Used this idea only with sand by putting a brake backing plate with all it's dips and bends inside the tank and then blasted it which ricochetted the sand every direction and cleaned the blind underside of the top. Guess even a blind hog finds the acorn once in awhile. Oh yeah, all the trouble because it's for a 1941 International Harvester 1/2T K series pickup---not found easily.
  2. SinclairChevy
    SinclairChevy Member
    Keokuk, Iowa
    Necessity is the mother of all invention... Glad your improvised reflector worked for you, Evan!
    Damon
  3. Blueflame236
    Blueflame236 Member
    Norway
    Creativ solution !
    I love the " learning by doing " work and learn more from that then all the books availeble about all kinds of restoring trucks/cars subjects !
    Thanks fore sharing Martinius.
