Leaking Oil
Discussion in '1947-1954' started by 1BAD54, May 5, 2008.
  1. 1BAD54
    1BAD54 Member
    I Ck Dip Stick Tube And Tapped In In Tighter, But I Have Oil Leakig From Around Distributor Where It Goes In Block And Some Spits Out At Top Of Tube Where Dip Stick Goes In. Is This A Major Problem Or Does Distributor Have Orings That Seal When Put In Block. I Have Never Taken It Out Before. Any In Put Would Be Great. You Guys Have Been Great To Talk With. Hope I Gave Enough Information.
  2. Bilbo
    Bilbo Member
    Magnolia, Texas
    I'm not sure what the solution is, but it kinda' sounds like you're building crankcase pressure? Maybe one of the experts can offer more, those guys are incredible with what they know.
  3. Steve Katzman
    Steve Katzman Member
    Breather on the Barbie
    You might want to try the breather on the barbie trick. Even if its not your problem it will be good for the engine:) Make sure to use lots of jalepenas:D
    (Really, you will be shocked at what comes out of the thing after its cooked and it could be what is stoping your crankcase from breathing right)
  4. 1BAD54
    1BAD54 Member
    Hey I Want To Thank You Guys. It Was Crankcase Pressure. I Replaced Oil Cap And It Is Not Leaking Out Out Dip Stick Tube Or Around Dist. You Guys Are Great. Hope I Can Return The Favor Some Day. Neil
  5. vwnate1
    Really , you should read up on the road draft tube posts and consider BBQ'ing it as bead blasting not only won't get the crud out , it'll ruin your engine in short order ~ replacing the oil filler cap shouldn't have fixed the problem ....
