Leaking Radiator
Discussion in '1947-1954' started by Just Learning, Aug 27, 2007.
  1. Just Learning
    Just Learning Member
    My 52 3/4 ton truck just came back from getting painted and looks great. But now the radiator has a leak. Its always something.
    I suspect I will need to buy a new one, probably the one that Classic Parts offers. But I'm out of money until next Spring!
    Any thoughts on making it last until then? Or do I just carry around with me a gallon of water to re-fill if needed out on the road.
    Thanks,
    Eric
    Eric ;
    The coolant is clear and not muddy nor cloudy , right ? if not , flush it untill it's clear then add a tube of " Silver Seal " ~ it comes in plastic tubes and is simply killer stop leak .
    Remember : NO TAP WATER ! use distilled water from the grocery store , this retards the corrosion buildup caused by minerals found in tap water .
    Leaving the radiator cap loose will reduce leaking too by relieving the pressure .
  3. Just Learning
    Leaking Radiator Followup
    Nate, I am assuming from your message that I put the Silver Seal into the radiator with the radiator full, right?
    By the way, I am running a 50/50 mix in the radiator. Is that about right?
    Thanks, as always.
    Eric
  4. Kens 50 PU
    Ooh, ooh, pick me! I know the answer!
    Eric, the Great One has covered this before. And I hang on every word. 60 percent DISTILLED water and 40 percent anti-freeze. Make sure to reverse flush the radiator until it runs clear, then add the Silver Seal according to the directions.
  5. vwnate1
    Yep , never more than 40 % coolant (unless you're in Minnesota !) and ALWAYS read and follow the instructions on the tube of Silver Seal....
