Looking for...
Discussion in '1960-1966' started by Arizona64, Jan 28, 2002.
  1. Arizona64
    Arizona64 Member
    Sierra Vista US
    I'm looking for a steering column (automatic) for a 64 Chevy C10. All linkage is on the floor, so it doesn't matter. Let's make a deal!
    Regards,
    Arizona64}>
  2. dvalentine
    Hi Arizona, Consider swapping out to a later model column "without" the built-in javilin. The one that is in there now uses a solid shaft from the steering box to the cross-hairs on the middle of your chest. Swapping to a later model (tilt or other wise) will allow the use of a double-d shaft with universal joint type connections.
  3. Arizona64
    Arizona64 Member
    Sierra Vista US
    What do you think of Ididit columns? Could I use a "newer" column, even though I don't have power steering?
    Regards,
    Arizona64
  4. dvalentine
    IDIDITs' are a really fine column with a really fine price !!!!
    You will have better luck at swap meets/e-bay and save many American dollars too. If you are building a "money is no object" cruisin Queen then the IDIDIT is your baby. I picked up a rebuilt tilt column without the ignition, ( I wanted to keep mine in the stock position) for $150. I got luckey, but I've seen the equivilant on e-Bay for close to that. Shop carefully and don't get caught in a bidding frenzy..
    Dennis
  5. Arizona64
    Arizona64 Member
    Sierra Vista US
    Dennis,
    Thanks for the usefull info! Hey, did you go power, or stick with manual steering?
    Regards,
    Arizona64
