Lowering probs
Discussion in '1960-1966' started by Clark J, Mar 24, 2008.
  1. Clark J
    Clark J Member
    Minnesota
    Hey guys I'am a newbee here...I have a 62 SB stepside that I put 4in lowered springs out back and now the wheels aren't centered in the wells,is there any fix??Everything is stock and the box is where it should be so I'am at aloss!!
  2. Hotrodkilroy
    Hotrodkilroy Member
    Wilton,Maine
    did u use an adjustable trailing arm??
  3. Clark J
    Clark J Member
    Minnesota
    Sorry new the truck world,I think there stock.It had the bubba big tirers on it when I got it..it looked like a 4X4.
  4. dvalentine
    If you meant centered in the wheel openings, ( side view), the wheels on these trucks were never centered perfect. Lowering the truck points it out in a hurry.
    If you mean they are not centered side to side, then you need to use an adjustable track bar, that thing that mounts on the left fram rail and goes down to the rear center section of the differential.
    If you went lower than 4 inches in the rear look at the Super Adjustable Track Bar by Early Classic Ent. ( http://www.earlyclassic.com)
    The track bar "should" run down hill from the frame rail, NEVER up hill....
    Val
  5. bobcat77
    bobcat77 Member
    Denison, Texas
    Check out the mods that Vin63 is doing to fix this, it's in another thread.
    "Fender Modifiations and intro"
  6. Vin63
    Vin63 Member
    SoCal
    ;) Here's a photo of what I'm currently doing...
  7. vp23271
    vp23271 Member
    Huntington Beach, CA
    I just lowered mine a week ago and I agree with dvalentine, most likely the track bar.
  8. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    I also agree with dval, infact i had early classics build me a custom track bar thats slightly longer then the one they usually sell due to the trailing arms i put in landed on the axle slight further out then the stock ones. Just use a ratcheting tie down, pull the axle to were your measurments come out exactly centered, frame to inside of brake, then adjust the track bar and bolt it in.
  9. dvalentine
    To ad to what Kustom said, the truck "should" be on the wheels with all the weight loaded to the springs before adjusting the track bar. Drive on ramps or drive on lift is REAL handy right about now.
    Val
  10. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    thats for sure dval!!
