Lowering the radiator position and using a 160 F.thermostate.
Discussion in '1947-1954' started by Blueflame236, May 4, 2009.
  1. Blueflame236
    Blueflame236 Member
    Norway
    When swapping the 216 for a 235 engine (55 model).
    I installed the short waterpump and the result is that the coolingfan sits aprox.5 cm lower then in the 216 CI. wich is closer to the thermostatehouse.
    A simple way to get better engine(235 CI) cooling is to lower the radiator a bit aprox.5 cm in its frame,you have to drill 6 new holes but this is a peace of cake. Using a160 F.thermostate instead off the regular 180 F gives a better cooling. It opens earlyer wich is good fore your engine..
    Some kichen bench sience;
    A 160 F.thermostate opens at ca. 72 celcius
    and the 180F. opens at ca.90 celsius
    Matinius.
    Well , NO ~
    Your engine runs better & lasts longer with a 92° C (185° F) thermostat .
    Running the engine as close to boiling as possible makes the most power and best fuel milage too .
    Most folks just use a brand "F" 390 V-8 fan and WP pulley for clearance .
