manifold 216 235 swap
Discussion in '1947-1954' started by dan cocomise, Aug 16, 2011.
  1. dan cocomise
    dan cocomise Member
    can i put 216 intake exhaust manifolod on second series 235 and use 216 alinment rings will it work this truck is not very good shape.thanks
  2. Guest5979
    Guest5979 Guest
    216 on a 235
    some will say no butt i put my 216 split manifold on a 235 engine so far so good no leaks butt. you can`t use the rings just line up good .
    i think i used 216 gasket set.
    hope this helps
    Robert
