max rpm 235
Discussion in '1947-1954' started by jnycnuk, May 12, 2013.
  1. jnycnuk
    jnycnuk Member
    what is max cruising rpm for a 235?
  2. Mike1951
    Mike1951 Member
    Osawatomie, KS
    Of a dead stock 60 year old motor? I would like to know also.
    Papy
    216/235/261 RPM's
    For cruising , 3,000 is the sweet spot .
    Revving it higher as you're accelerating up through the gears is fine , just don't expect it to last long if you exceed 3,200 RPM's unless you're going to up shift soon :eek: .
  4. jnycnuk
    jnycnuk Member
    thanks guys it's totally stock ... for the moment.
  5. vwnate1
    So Then.......
    Tune it sharpish , adjust the valves , HOT CHANGE the oil & filter remembering it likes and needs thin oils then go DRIVE AND ENJOY IT ~ you'll soon discover why CHEVROLET was for decades the most popular truck in America ~ it's a cheap truck yes but very peppy and easy / fun to drive when everything's properly adjusted , evn in your wheezy old worn out engine that smokes badly .
  6. Coach529
    Coach529 Member
    Jamestown, ND
    What about a bone stock 216?
  7. vwnate1
    " Target Lubrication "
    Right about the same , assuming you're using good quality oils and the oil pan isn't dented in as that affects the aim of the oiling nozzles .
    In general , any long stroke engine (babbit pounder or pressure lubed) will hum right along well @ 3,000 RPM's , if it's properly tuned , even a worn out 216 only needs 1/2 throttle or LESS to make this RPM / speed on a level road in top gear .
    I can't remember ever blowing a rod on a 216 although I well remember nursing knocking 216's for many years of daily use......
  8. Coach529
    Coach529 Member
    Jamestown, ND
    Thanks Nate!!
    You always hear that these 216's do not like RPM's........so I was curious!!
