RE: motor builder
I personally like the new vortc truck heads they flow just as well as some of the well known aftermarket head and will easily support 380 HP I read in an article from one of the high performance mags, that these heads, even with 1.94/1.50 valves, flow better than the World Products Sportsman II heads with 200cc intake runners, and 2.02/1.6 valves, there are 2 probs one you have to run a different intake. I think PN#2116 is the Performer. It is basically a stock replacement performance intake. It has an rpm range of idle to 5500 rpm. If you want the high rise dual plane Performer Rpm, Pn#7116. It has an rpm range of idle to 6500rpm both from edelbrock and gm has 2 or 3 of them. they are about 430 where i am but you can get them for about 400 some times, then there are the springs they wont live very long if you go bigger than 460 lift. the vortecs need self aligning rocker arms too and are center bolt style valve cover heads but they out flow the old 2.02 1.60 fulie heads i think they have 64 cc combustion chambers
