Motor ?
Discussion in '1947-1954' started by graham, Feb 9, 2012.
  1. graham
    graham Member
    Houston Texas
    I was just wondering what is the difference is between the 235 truck motor and a 235 car motor. I found a car motor that has the two carburetor set up and header that has been rebuilt.
  2. fab51
    fab51 Member
    Central Missouri
    As I recall, there isn't much difference. The truck motor has a solid lifter cam and an aluminum cam gear while the car motors had hydraulic lifters and a fiber cam gear. Oh, and the colors were different. Other than that I'm not aware of any other differences.
  3. Kens 50 PU
    If I recall correctly, the car engine had hydraulic lifters only if it was coupled to a powerglide tranny, but I could be wrong. Oil filler cap was located in the middle of the valve cover on car and in the front on trucks.
  4. Blueflame236
    Blueflame236 Member
    Norway
    Link 235 engines
    Some links ;
    Scrolling through these sites gives some other information aswell ;
    http://50classicchevy.com/
    http://enginefacts.com/chevrolet235.php
  5. vwnate1
    The Differance :
    Technically , a " Motor " is tethered (think APU , Gen Set. , Trash Pump etc.) whereas your old truck has an " Engine " as it propels a vehicle.... :cool:
    Had enough useless trivia ? good :
    GO GRAB that 235 ! . the hydraulic liters are apt. to clatter a bit @ hot idle but otherwise it'll be fine , I hope you're not going to pay a whole lot for it , the dual carby setup is only worth $250 Max. , I just sold mine .
    Get it , scrub it Hospital clean & re spray it the correct Truck gray color , seal as necessary and slap it in , go run the wheels off your rig , you'll love the dual carbys , they increase fuel economy too .
  6. customhotrod
    customhotrod Member
    "The Rock" Sweden
    Must depend on the year, cuz the '60 I have, have the filler in the middle and it came from a truck and the '56 have the filler in the front and I took it out of the car it came from! Matching numbers and all!
    Klaus
  7. fab51
    fab51 Member
    Central Missouri
    According to this, it is based on year. I can confirm this, at least in part. I have two '56 and one '57 235's. All three have the filler at the front of the valve cover.
  8. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Nice link - thanks!
