Moving Gas Tank & Door Rust
Discussion in '1947-1954' started by wrongpaw, Oct 6, 2006.
  1. wrongpaw
    wrongpaw Member
    Minnesota
    Greetings All
    Started working on the 47 3100. Got the seat out and am in the process of
    vacuuming out the 2" of mouse poo. What's the lowdown on moving the tank
    from the cab to between the rails? And, is there a tried and true method of
    getting the surface rust out of the "inside" of the doors?
    Thanks
    Wrongpaw
  2. Kens 50 PU
    hey wrongpaw, you do plan to recycle that poo, don't you?:D I've never used this product before, but after reading stuff about it, it may be worth investigating. It's called Rust Bullet and it's supposed to be worth it's weight in gold. Supposedly, you can apply it directly to a rusted surface and it stops the spread of it, blah, blah, blah. the website is www.rustbullet.com if you want to check it out.
  3. dngaspersich
    dngaspersich Member
    Wrongpaw, if your truck is actually a '47 the gas tank should already be between the rails and not in the cab. If that is not the case, find a 47-48 pick-up or up to '53 panel/suburban and snag the tank & bracketry to bolt to frame. On the pick-ups it fills through the passeger bed side. Dave
    You can use Phosphoric Acid to neutralize rust , it will not eat good metal , only rust .
    DO NOT use Muriatic Acid as that _will_ eat good metal ! .
    There used to be a product called ' Rust Mort ' , after you wire brushed the loose scale off you'd apply it and it stopped the rust and turned it into a good base to paint over ~ I saw a horribly rusty Mercedes Benz UniMog (military truck) get saved by using this stuff once...
    As mentioned , '47s have the tank under the bed .
    Many have used old Econoline van fuel tanks between the frame rails to the rear or the rear axle , others like the Mustang / Maverick tank .
    Just beware of the trap of installing the filler under neath a drap door in the bed ~ while cool looking this is a real PIA in actual use and few are happy with it after actually usingthe truck so modified .
  5. brit 50
    brit 50 Member
    Essex England, the motherland
    Of mice and men
    what is it with these trucks and mice? everyone says they have cleaned out the black pellets (english gentlemen dont say poo) ive found a nest in the bottom of the A pillar and one in each door! are they pests or do they just have good taste?
    ________
    Buy herbalaire
  6. henry51
    henry51 Member
    Evansville IN
    I recently pulled my seat and tank (to seal the tank). and didnt find a speck of poo.
    Henry
  7. vwnate1
    Trust me , they're pests :mad:
    My truck is about the only vehicle I own that doesn't get rodents in it...
    I have the rotten little buggers living in the walls of my house , I laid out poison and one had the temerity to die in the batheroom wall...
    Stunk to high heaven for a month .
  8. Bill Hanlon
    This must be the first time the word temerity has been used in an old truck environment. Leave it to Nate to break another barrier.
  9. vwnate1
    What can I say ? :d :d :d
  10. brit 50
    brit 50 Member
    Yeah, but it takes a real Brit to get everyone talking poo!!!!!!!!!
    ________
    GLASS PIPE PICTURES
  11. vwnate1
    Crap Talk
    Or ;
    An ex-farm boy like someone on this very list........ :confused:
    :D
  12. brit 50
    brit 50 Member
    Mice, peppermint chocolate on an ol fashioned neck snapper trap, never fails, used to have farm behind my old place and come wintertime the little blighters used to move into the loft. i know its not nice to kill them and my daughter hated me doing it but when they took the last beer outta the fridge, their number was up!
    ________
    Captiva
