I tried for several days to get the engine in my "new" 54 truck unstuck. I finally decided to pull the head & see inside. The cylinder bores & piston tops look good . The piston tops look practically new . The piston tops are stamped "STD" . That probably indicates replacement pistons , right ? Factory pistons were not stamped , were they ? The reason the engine was stuck was not a piston/cylinder problem but appears to be a lifter/bore problem . Mice had gotten inside the valve cover as the oil cap was missing . They had carried cotton , from the seat ,no doubt & built a nest about the middle of the head . The mouse pee & droppings had gone down around the pushrods & got to the lifters.They all seem to be stuck . I plan to spray each one & try to free them . Any suggestions and/or words of encouragement will be appreciated . Thanks .
