Need a little help...Hyd Clutch & power brakes
Discussion in 'Blazers/Jimmys/Suburbans' started by Soba_03, Dec 17, 2007.
  1. Soba_03
    Soba_03 Member
    Ok folks, I have a 1961 Burb, it's got hyd clutch. I'm trying to figure out if there is some way to apply power brakes and maintain the Hyd clutch.
    I know that CPP sells a brake booster and hyd clutch cyl combo package. But I've already bought the brakes and spindles and booster and master cylinder. I'm trying to get around the hyd clutch with out haveing to remove it. I know that someone else has to have figured out how to do this.
    Please any help would be great. Pictures of your setups would be wonderful.
    Thanks.......
  2. The Pack Rat
    The Pack Rat Member
    LaGrange, Illinois
    You got to be a little more specific. Which part of the system are you trying to avoid having to remove? Slave cylinder, clutch master cylinder, or hydraulic throwout bearing?
