Need Electrical Help 1966 C-!0 Shortbed
Discussion in '1960-1966' started by uncfan, Jul 26, 2009.
  1. uncfan
    uncfan Member
    I replaced the battery cables and battery in my truck. I made sure all the connections including the short pigtail from the positive cable were tight. It started right up but I couldnt turn it off with the key. It whet off when i disconnected the cable but now when I just connect the battery cables the GEN light comes on even with the key in the off position. Any ideas?
  2. dvalentine
    Go over your connections at the starter. Something is wrong there....
    dv
  3. drabo
    drabo Member
    Patrick AFB, Florida
    Make sure the battery cable isn't touching one of the little wires on the smaller post.
  4. Vin63
    Vin63 Member
    SoCal
    X2...it sounds like the starter connections might be mixed. If everything there checks out, then I would start looking into the alternator connections for feedback sources. Good luck.
  5. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    make sure one of your starter wires isnt grounding on a header, been there done that!
