Need Help
Discussion in 'Performance, Engine, and Transmission' started by John O, Aug 2, 2020.
  1. John O
    John O Member
    Father has a 235 engine, 1953 block.. Completely rebuilt. Has weak firing on a couple of cylinders. Has had the distributor rebuilt. (New points, condenser, cap, etc twice).. New plugs, wires.. Everything anyone can think of... HELP!!!!
  2. KYGEARHEAD
    KYGEARHEAD Member
    Fancy Farm, KY
    John O. Have you replaced the wires and coil also? If so check the voltage going to the coil. Should be the same voltage as the battery once the key is in the "ON" position.
