need later 235
Discussion in '1955-1959' started by old skool 51, Aug 7, 2008.
  1. old skool 51
    old skool 51 Member
    im plannin on rebuiding a 235 for my truck but i have a 51 so the motor i have doesnt have the appropriate oiling system for my plans :( i need to find a later 235 out a 54 or newer.anyone got one or know where i can find one? i found a couple online but the people sold em already.
  2. coyote
    coyote Member
    I have a 1960 235 68,000 miles run good if you interested
    Mike
  3. coilover
    Nothing wrong with a 54-57 but the 58-62 have several better features. Mike's 1960 would be worth checking out.
  4. ccharr
    Where do you live?
  5. vhpeddler
    vhpeddler Member
    235 info needed
    What are the better features of the '58-'62? I am about to put a '60 235 into a '57 3200 which has its original 235. Do you know what is not interchangeable? I plan to take rebuilt parts and , other items off my '57 235. Any differences I should be aware of?
    I appreciate any input you may give me. Thanks
  6. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    I have a 58-235 short block with 5000 miles on it. It has .40 forged pistons, shot peened and I beam ground rods with ARP rod bolts, balanced, with a Hi performance cam and a custom built 8Qt. oil pan. This engine spun a rod bearing. It needs to have the bearing journal on the crank welded and reground and 1 rod resized. It wouldn't take much to get this block back in shape. 500.00 for the short block 600.00 with a good buildable head. Located in Sonora Ca. Big Tim :cool:
  7. coilover
    The main difference is the 58 and up no longer used shims on any bearings, just replacement shells like all modern bearings. Not sure but maybe the 882 head was introduced also.
