need shifter for my 62 want advice
Discussion in '1960-1966' started by LostinAl35986, Oct 12, 2002.
  1. LostinAl35986
    LostinAl35986 Member
    Rainsville USA
    I have 62 fleetside and I'm wanting to put a three speed in the floor. I believe the trans is probably original . I'm thinking Hurst Indy , but the height ,looks and operation are all important to me . Thanks LOST
  2. cowboy
    cowboy Member
    all You got to do is be able to get some material (steel rod) and make the shifter leaver taller than the one that comes with the kit. you should bend it and probably flaten on end of the shifter so you can drill mounting holes in it easier.
    you could make a really tall shifter, or you could go for the just right for you lenght. when i put my muncie 4spd in my truck i'm going to make a shifter for it and it is going to be a real tall shifter.for that different look.
    cowboy
    1961 chevy 1/2 ton shortstep known as sarah (496 big block coming soon)
