new gas tank
Discussion in '1947-1954' started by richie d, Aug 14, 2006.
  1. richie d
    richie d Member
    :confused: has anyone installed c.d.'s new gas tank and flex hose, what adapter fitting did you use or did you drill and retap????? any help would appreciated,
    Untill you've tried to save your old tank and failed , never wa$te your time and $ on re-pop tanks as they ALL suck and about 2/3 of them LEAK too ! . not good .
    It's a rare tank that cannot be saced by carefull cleaning and relining .
    Look in the 'phone book under Gas Tank Re NU , it's a natio wide chain that specializes in this typ of repair .
    The re-pop tank should have fit right in the alotted space with no mods and began leaking as soon as you filled it up .
    Maybe they sent you the wrong tank ? just a thunk .
  3. richie d
    richie d Member
    new tank
    It never had a tank when I got the truck so I guess I have to hope I got the 1/3 that dont leak. Inline tube hooked me up but I have to drill and tap. Hopefully theres enough meat around the fitting. Called chevy duty, Im sorry classic parts, they knew what I was talking about. hopefully they will remedy this problem.
  4. Canby52
    Canby52 Member
    Gas Tank
    I have a tank with sending unit and fill neck. Never leaked and I'm not going to use it.
