New tank but no way to fill it.....
Headwind
Feb 24, 2005
21
Location
San Diego USA
I have a '65 C20 Fleetside that now has a poly gas tank mounted where the spare tire/bracket used to be. The tank was made as a replacement for a 69-72 Blazer but also can be used on 63-72 pickups. I'm having trouble finding a filler neck, a neck hose.....I know a lot of you have done this before & I'm hoping for some ideas/direction as to where you have the filler neck located & where you found the parts needed in the correct size - 1 3/8. Thanks:)
RE: New tank but no way to fill it.
Headwind:
There are a number of companies that offer an aftermarket filler neck, as well as the hose, cap, fuel lines, sending units and actual fuel tanks. I have seen them before at Classic Performance Products website. Also, there are many options available from donor vehicles if you do not want to go the new route. I believe MAR-K also sells a number of filler assemblies for the cab-to-bed fuel tank swap on this year truck. Best of luck with your project.
LILRD66 ('66, C-10)
BCKNBLK ('66, K-10)
