Newbie and need Turn Signal Assembly Help
Discussion in '1967-1972' started by TxAg, Sep 22, 2008.
  1. TxAg
    TxAg Member
    N. Texas
    Howdy, All.
    New to the forum, so great to be here. Also new to restorattion, working on a '68 Fleetside, 3-speed, 252 I-6. Everytime I remove another part, I find 10 more new parts that need to be fixed or replaced. Even the transmission was starting to fall apart on me, much less the engine. However, nothing so bad that it couldn't be repaired and now running great.
    I am definitely learning quite a bit, and hopefully getting close to the re-assembly stage. I am getting the body parts media blasted, straightened, and primed. Hoping to start assembling by mid-Oct.
    I have one concern that is a bit off, but I wanted to start asking now. Can anyone provide a picture of turn-signal assemmbly assembled in the column. I was not around when it was removed, and need a little help.
    Look forward to following the threads and learning from the masters.
    TxAg
  2. jef5150
    jef5150 Member
    Calaveras County,Calif
    if you come back....here it is.
    Kind greasy!
    jeff
