Off topic - GM 10 bolt ratios
Discussion in '1947-1954' started by Bill Hanlon, Jan 31, 2014.
  1. Bill Hanlon
    My 52 GMC 3/4 ton is equipped with a late 60s GM 10 bolt rear end. I'd like to figure out the ratio without opening up the cover. My buddy Ken and I did the "chalk mark" measurement today. One turn of the tire resulted in an estimated 3 and 5/8 turns of the driveshaft or a ratio of about 3.62:1. The down side is that I don't think GM made such a ratio. I know GM had the following ratios, 2.41:1, 2.56:1, 2.73:1, 3.08:1, 3.43:1, 3.55:1, 3.73:1 and 4.10:1. A 3.63:1 would be mathematically easy using an 11 tooth pinion and a 40 tooth ring, but I have not found such a beast (yet) using Google.
    Any of you have first hand knowledge of such a ratio, or a pointer to a web page showing one?
  2. RidesWithYah
    RidesWithYah Member
    Lexington KY
    Do it again, making ten turns.
    Far more accurate.
    (I'm guessing 3.73s)
  3. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    With a standard open (non posi traction) differential raise one wheel off of the ground, mark the tire at the 6:00 position, mark the drive shaft. Turn the tire exactly 2 full turns. Count the number of times that the drive shaft turns.
    2-3/4 turns of the drive shaft = 2.73, just past 3 turns = 3.08, 3-1/3 = 3.23 or 3.31, almost 3-1/2 = 3.42, just past 3-1/2 = 3.55, 3-3/4 = 3.73, just past 4 = 4.10 or 4.11.
    With a good solid limited slip differential (posi) raise both wheels off of the ground and turn both wheels exactly 1 full turn. Everything else is the same as above. You can also do this with a standard differential as long as both wheels turn exactly 1 full turn.
  4. Bill Hanlon
    Good idea. I'll try again in the morning.
  5. Bill Hanlon
    Took RidesWithYa's good advice and measured 10 wheel turns. It's a 3.55:1.
  6. ol' chebby
    Pretty good all around ratio, near perfect for an overdrive.
  7. Bill Hanlon
    No OD on my truck, but 31" tall tires makes for around 2300 RPM @ 60 MPH or 12.5 MPH at full scream in granny gear.:eek:
