Oil Change Fun
Discussion in '1947-1954' started by vwnate1, Dec 26, 2007.
  1. vwnate1
    NOTE : this on a non GM vehicle so stop reading now if it'll bother you .....:rolleyes:
    I decided to do some routine lubrication service on my old Ural Moto to-day , when I pulled out the magnetic oil drain plug , a drop of water ran out followed by the usual black engine oil , thin like water from the polymer
    chain having been chopped up by the straight cut timing gears ~ looking at the magnet , I saw some sharp looking SWARF , a 3 MM woodrfuff key and a short bit of safety wire or perhaps part of a wire typ circlip :eek:
    The tranny was the usual green gear oil as it drained out ~ waitaminute ! this thing uses engine oil in the tranny ! this green color means the speedo cable seal is again leaking and allowing wash and rain water to run down it and into the gearbox :mad:
    The final drive had just enough gear oil to reach the dipstick , not taking _any_ chances , I drained & re-filled that too ;) .
    As far as I can tell , the heads have never been off this engine so I guess Ivan dropped the woodruff key in as the engine was being assembled .
    I took a nice hard test ride down to South Central L.A. and fixed some window screens for SWMBO , it ran fine , there and back , so I guess all is well .
    If not , it'll blow up and I'll snivel a bit then fix it , using better quality Western bearings & seals plus I'll do some basic blueprint work on the heads as they're rough , cobby buggers as built .
  2. Kens 50 PU
    Nate, I'm dying to ask you this question. Does that bad boy have a sidecar? Every pic of a Ural I've seen has one! That's the only way I'd ride one nowadays!:cool:
  3. Steve Katzman
    Steve Katzman Member
    Ural
    Do they really have woodruf keys in those things? Sure its not a woodrufski:confused: Could be a commie plot; sell mortorcyles in the US and then after 30 years the keys all fall out and everything stops:D
  4. put-put
    put-put Member
    Northwest Florida
    I had 2 "hacks", both on BMWs. A Jupiter on a 75 R90 and a fiberglass (can't recall the name of it) on an R60US. Hacking it wasn't really too bad. Had to build up those chest and forearms... Really a hoot in the mountains though. Recall one time on a reverse camber turn that i ended up looking up to see my wife about 3 feet above me; her expression was "priceless".
  5. vwnate1
    Ural Pictures
    O.K. , here ya go ! it was built with a sidecar but I don't cotton to them so I left it behind in Washington when I bought it .
    I ride it as a Solo , pretty much everywhere ~ think of it as a Russian tractor with only two wheels . :)
  6. Zig
    So what the hey! Another picture of our leader, but just like the avatar, it won't enlarge so I can see what the heck he, or his bike, looks like! Nate, I guess you're destined to be a pin sized dot on my screen... Any other "Attached Images" open up to a viewable photo, but I click on yours and nothing happens!
    Nutz.
  7. vwnate1
    Be Glad !
    As my picture might wreck your monitor ! .
