Oil drain plug leaks, threds look and fill good.Oil heats up it drips evon more.Any quick fixes. thanks
Make shure you have the little plastic or rubber gasket under the drain plug, like some modern cars have, sometimes this will help.
Oil Plug Weeps & Seeps Never , EVER use a ribber drain plug gasket ! . Only a hard one , copper , fibre , aluminum , nylon etc.
Teflon works good too. Glass Filled Teflon, a.k.a. GFT, is good up to 700 degrees. The replacement pan I bought for my sbc many moons ago came with a GFT gasket.
