Oil Filter on 59
Discussion in '1955-1959' started by blackbeard, Aug 25, 2008.
  1. blackbeard
    blackbeard Member
    Can anyone tell me where the oil filter on a 1959 Chevy is located? The engine is a 235 striaght six. I have looked everywhere and cannot seem to find the oil filter. Also does anyone no where to get a replacement carb for that engine? It is a carter type yf.
    Thanks
  2. Kens 50 PU
    Oil filters were add-on options for these engines. Most people put on what is referred to as cannister oil filters. They generally were mounted on the exhaust manifold. Here's a picture of the one I put on my 235.
    Hope this helps.
    Ken
  3. blackbeard
    blackbeard Member
    Where did you get your filter?
  4. Kens 50 PU
    My granddad ran a Gulf service station/garage for years and when he retired, dad and I scarfed up all of the parts he had in his shop, of which the oil filter was one.
    This oil filters are still available if you look long enough. I've seen them on Ebay, seen them at swap meets, etc. Just be sure to get all of the hardware for it if you find one, such as the U-bolts and fittings.
    NAPA and others FLAPS still carry the elements and most Flaps can still make new lines for you also.
  5. blackbeard
    blackbeard Member
    I did notice you have the same air filter that is on my 59 Chevy. How does the filter housing come apart so you can clean the element? I cannot seem to get mine apart for cleaning.
  6. blackbeard
    blackbeard Member
    Ken,
    Is that an AC oil filter canister? Can you tell me how to install the hoses and where they hook into the engine? What size element do they use 5 or 6 inch? I just won an AC oil filter cannister on e-bay for $27 that is supposed to be for a GM is this a good deal. The inlet and outlet fittings are missing. Do you know what type fittings they take and what size? Thanks for all your help. That is one beautiful truck you have. Hope mine will be there one day.
  7. Kens 50 PU
  8. blackbeard
    blackbeard Member
    Thanks for the info. What element does the canister take? Where can you purchase them?
    Thanks
  9. Kens 50 PU
    Mine takes the 5" element and most FLAPS carry them. So does our host, Classic Parts.
    Wait until you get yours in hand to verify what size you'll need.
  10. blackbeard
    blackbeard Member
    Ken,
    I went to install my canister and there is already a t where the oil pressure line is with a line leading to the passenger side of the engine and connecting into the cylinder head. I have also noticed the oil pressure guage fluctuating at idle from low to high. There seems to be less fluctuation after the engine warms up. Any suggestions? Can I still install the oil filter? Could I have a blocked oil passage? Can I put another t on the existing t?
    Thanks
  11. blackbeard
    blackbeard Member
    Anyone ever run into this problem? I think what I m seeing is a standard GM repair for a blocked oil passage to insure oil gets to the rocker arms, but I am not sure. Can anyone tell me what is the best way to install my AC oil filter canister and where the inlet hose should connect if there is already a t on the oil pressure line? I have seen the instructions on this forum. Any help would be greatly appreciated.
  12. ronaldg
    ronaldg Member
    u-bolts
    ken u-bolts are availible at any auto parts store thats where i got mine. there the same ones they use on mufflers i got mine at pep boys dont know if you guys have them where you live but any parts house or muffler shop.
  13. blackbeard
    blackbeard Member
    Ron,
    Thanks for the reply. I am still trying to figure out why there is already a t where my oil pressure line is connected with another line leading around to the other side of the engine and connecting into the cylinder head. Should I install anther t and connect the inlet hose and oil pressure line off of the existing t? Surely someone else has run into this same problem. Just want to make sure I get the oil filter canister connected properly.
    Thanks
  14. blackbeard
    blackbeard Member
    Anybody? Gotta be someone on here that knows about this. Just trying to get my filter installed. Thanks
  15. ronaldg
    ronaldg Member
    picture may help
    dont know why one line goes around other side but this is the correct set up i hope it helps
  16. ronaldg
    ronaldg Member
    forgot picture sorry
    check it out
  17. blackbeard
    blackbeard Member
    Ron,
    Thanks for the response. That answers my question.
