oil pan
Discussion in '1947-1954' started by ronaldg, May 19, 2008.
  1. ronaldg
    ronaldg Member
    can someone tell me if an oil pan off a 235 ingine 1958 chev biscayne will be the same as my oil pan which is a 235 ingine 1950 chev half ton pickup thanks
  2. Chiro
    Chiro Member
    IIRC 1950 pickup trucks came with a 216, not a 235. That would make your engine a later engine. Check the numbers on it and run them. don't know if the oil pan will fit or not though.
    Andy
  3. ronaldg
    ronaldg Member
    it is a later engine and a 235
  4. 64shortbed
    64shortbed Member
    scott city ks
    from 54 to 62 and some 63 the 235 was the same. pan should work i would think
  5. Kens 50 PU
    Not all 235's were created equal
    You need to determine if you have an early model 235 or a later model full pressure 235 because they will be different.
    I seem to recall that someone here had a problem finding the correct oil pan gasket for his 235 and it was determined that he had a later model engine.
  6. Kens 50 PU
  7. ronaldg
    ronaldg Member
