oil pressure gauge
Discussion in 'General Chevy & GMC Pickups Talk' started by crpsh40, Oct 2, 2000.
  1. crpsh40
    crpsh40 Member
    I have recently purchased a 1992 chevy s-10 maxi cab. It is a real clean truck. I am concerned about the oil pressure gauge that jumps around and fluxuates terribly when the motor is idling. When you get up to speed it stops and shows pleanty of pressure. Anyone else have this problem or know the solution.
    sincerely
    pressure point
  2. Craig
    Craig Guest
    What is happening is a standard GM problem.It is gauge problem.Check your gauge for a loose connections.
    Craig Hager
    tech1@chevyduty.com
  3. crpsh40
    crpsh40 Member
    I went to the people I bought it from. The mecanic indicated the gauge problem can be resolved with a new sending unit. I will have the unit installed in a couple of days. Thanks for the insights.
