Oil Pressure Gauge
Discussion in '1947-1954' started by Slinger53, Sep 11, 2012.
  1. Slinger53
    Slinger53 Member
    Florence, Montana
    Replaced the old 216 in my 53 Chevy, with a 235 out of a 62 Impala. My current oil pressure gauge goes from 0-30 lbs. Question, with the newer 235, do I need to change out my oil pressure gauge with one that goes from 0-60 lbs?? Any help wold be appreciated.
    Slinger
  2. Bill Hanlon
    Morris Ranch TX
    You could change the gauge out to a GMC (60 pound) gauge or you could just use the Nate method.
    Nate method is "don't worry about the pressure when the gauge is pegged".
    No
    These are low pressure , high volume engines so as long as you see the needle off the peg above idle , you're good to go .
    Be aware the needle may rest on the peg at idle or so closely you'll have to look with a magnafying glass to see the gap , this is 100 % correct and normal .
    -Nate
  4. Slinger53
    Slinger53 Member
    Florence, Montana
    Thanks guys, this is helpful.
