One more question to bed restoring
Discussion in '1947-1954' started by wokri, Sep 2, 2009.
  1. wokri
    wokri Member
    Germany
    Hello guys,
    I have another question to the bed restoring. As you see on the two photos I placed the first sill on the frame. Is this as you can see okay so or must I place a rubber part between the sill and the frame.
    I ask this because there is a rivet under the sill and I think that can not be okay so.
    And one more question can someone tell the size between the sills? For remind I have a Chevy 3600.
    Thanks for your help
    Wolfgang
  2. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Wood Block
    Wolfgang - I'm not sure about your 3800, but the 3100 has about a 2" wood block between the frame and the rail. Please see the photo.
  3. ol' chebby
    Theyshould have a wooden spacer block, the 53 needs a 1 1/2 spacer to get the bed to line up with the splash aprons.
  4. GLRnTX
    GLRnTX Member
    Helotes, TX
  5. vwnate1
    Wood Bed Blocks
    Wolfgang ~ look at the photo of the wooden blocks and notice the bolt hole aligns with the grain of the wood ~ you can make your own blocks but this detail is VERY important ! failure to align the bolt hole with the wood grain will result in the block splitting in 1/2 very soon .
    If you look in older posts about bed blocks , you'll see how the fellows helped me out of this problem .
  6. wokri
    wokri Member
    Germany
    Interval between the sills
    Hello,
    a second question to bed restoring. How large must the space between the sills at a 3/4 ton truck? Has Chevrolet given a technical drawing?
    Ask
    Wolfgang
  7. ol' chebby
    They are the same size as the 1/2 ton. I find that the blocks usually need to trimed to make the fenders line up properly. Assemble the bed and fenders and then line them up with the running bosds and splash aprons, cutting the blocks to fit.
