Paint on Patch panels
Discussion in 'Classic Parts of America Talk' started by morepower16, Jun 3, 2008.
  1. morepower16
    morepower16 Member
    Houston Texas
    Just ordered and received some patch panels for the cab and they are black in color. Is this a primmer, can I weld thru it, do I need to remove it to spray 2K epoxy primmer? By the way, the pannels look great and I can hardly wait to install them.
  2. 64shortbed
    64shortbed Member
    scott city ks
    i forgot what kind of primer its called but it is a primer like coating. to weld you have to remove it were you are welding. to spray your epoxy primer on it you have to skuff it with at least 400 sand paper. i use 320 paper on my parts. if you dont sand it the primer, sealer, paint and clear (if you use clear) will not stay very long.
