paint stripping
Discussion in '1960-1966' started by rustbucket, Oct 19, 2002.
  1. rustbucket
    rustbucket Member
    New Braunfels USA
    Has anyone out there tried Removall from Napier Products ?
    (Check out their site...www.removall.com
    I saw their ad in "This Old House" and it is used on airplanes and cars as well..
    sure beats sanding...
  2. evers310
    evers310 Member
    Atlanta USA
    I use a product called Aircraft Remover, I'm using it right now as a matter of fact. I just stripped the drivers door down and I'm about to start the body work on it. I only had to use one coat to get all the paint off. Works great!
    '66 C10 Fleetside LWB 350/350
  3. Arizona64
    Arizona64 Member
    Sierra Vista US
    I'm not familiar with the products you talked about here, but I've used strippers before. I'd have to say be very carefull in the areas you know have bondo. The stripper will soften it, and you'll end up digging into it. My best suggestion would be to use a good DA sander and get a few rolls of various grit paper. Don't neglect your sanding block either!
    Good luck!
    Regards,
    Arizona64}>
  4. evers310
    evers310 Member
    Atlanta USA
    I'm taking everything down to bare metal so I'm not worried about the existing bondo. That stripper is some real powerful stuff though and yes, it will soften bondo.
  5. Rat66
    Rat66 Member
    Platte City
    Must be some good stuff. I have a '66 LWB as well and finally about
    80% done stripping. I've used various strippers and sanders and I
    think the sanding was the less time consuming. I got four layers of
    paint and the BEST stuff I could find still took at least 3 apps.
    to get down to metal.
  6. evers310
    evers310 Member
    Atlanta USA
    Mine has the original paint so it's a lot easier. I use some stuff called aircraft stripper. I got it from autozone.
