Por-15 warning !!!!!
Be aware this stuff is *
ermanent* so you *must* lay out drop sheets much larger than the truck unless you're working in the dirt .
Any little droplets you get on yourself , will be there until the skin exfoliates (fancy word meaning naturally wears out and is replaced by new skin) so if you work in an office or are the Deacon @ Church you're going to look funny for three weeks at least .
Next : if one drop lands on the garage floor or new cement driveway , SWMBO will get PO'd and your sex life wil change in ways you won't like
All you needs do is : wire brush the frame until there's
NO rust left upon it , so it'll pass the paper towel test , then wipe it clean with clean rags/towels & ether , allow to dry and paint on the POR-15 in gloss black , some will say it'll fade but it won't ~ that was 25 years ago .
Once the can is open , you must not close the lid again unless you've lain a sheet of saran wrap over it else the lid
will self cement into place , you'll never get it off again .
Brushes & rollers likewise , can be used untl they're stiff then must be bagged up and tossed , failure to do so will have a permanent mess on your hands .
Wear rubber gloves and old clothes you don't care about, they'll be ruined .
All this sounds negative I know but taking the time to follow all the steps and precautions and having the rusty , dented , pitted welded up old frame hospital clean , will result in a nice shiny black job that'll look GREAT and outlast you and any of your grandkids .
NOTHING is as good as POR-15 ! .
Nor as tricky to use
