Parking pedal want come self return if I kick it down
Discussion in '1947-1954' started by wokri, Aug 24, 2009.
  1. wokri
    wokri Member
    Germany
    Hello
    I'm to rebuild the parking brake of my truck. I think I have all the parts together, that I found. But after restoring the parking brake I have now the problem if I kick the pedal down it will lock but if I try to unlock it it want return.
    I think there's missing a spring, but where have I to connect it?
    Ask
    Wolfgang
  2. gary1of2
    gary1of2 Member
    Valley Springs, CA
    p.b. spring
    There is a little tab on top of the steel p.b. rod under the cab. The spring hooks there and goes to the cross member right behind the cab. The spring is in two pieces the spring and a piece of stiff wire with a hook bent on both ends.
  3. wokri
    wokri Member
    Germany
    Spring for parking brake
    Hello Gary,
    could you tell me the sizes of these spring lengh, diameter, strengh of the spring wire? Maybe I can get it here in Germany.
    Wolfgang
  4. Ruger338
    Ruger338 Member
    Since your truck is a 3/4 ton you may not have the clip he talks about. If not your spring will attach to the clevis under the cab since most 3/4 tons have a two piece actuating rod. This then clips with a long wire into the triangular piece off the frame. Mine had an additional small about 1" long c-clip for this purpose if you can't find it the spring/wire sold by Jim Carter should work you can see it on his site as Part number MEB113. I can measure mine if you would like the actual dimensions.
  5. GLRnTX
    GLRnTX Member
    Helotes, TX
    Another PB spring
    Don't forget the spring the Pedal Lock and the firewall (PN 3695565) inside the cab. Reference: Sect. 5, Sheet 3.00 in the F.A.M.
    Greg
  6. Keystoner
    Keystoner Member
    Pennsylvania
    Springs - Parking Brake
    Brake springs from the Master Parts Catalog
    Group 4.597 - Spring, Parking Brake
    Interior - 2 springs
    http://chevy.oldcarmanualproject.com/1929_54chevyparts/04/290.HTM
    http://chevy.oldcarmanualproject.com/1929_54chevyparts/04/288.HTM
    Group 4.827 - Spring, brake pull back
    http://chevy.oldcarmanualproject.com/1929_54chevyparts/04/308.HTM
    brake system truck pic
    Pull back spring shown in pic is attached to Cross Shaft, Group 4.788.
    http://chevy.oldcarmanualproject.com/1929_54chevyparts/04/304.HTM
    -Tom
  7. gary1of2
    gary1of2 Member
    Valley Springs, CA
    P.b. Spring
    The spring is 7 inches long, 3/4 inch dia. The wire hook is 11 inches.
