I need a passenger side manifold to fit my 1972 chevy custom deluxe. It is a 350 and a automatic trans. It has a big crack in it and is leaking bad. Cant spend much Thanks
Try some JB WELD on the crack. People have had good luck using that as a quick fix on exhaust manifolds. It won't work if the crack is across a bolt hole, but will seal a genearl leak caused by a crack. DVal
