Patch panel
poor54
I need to order some patch panels, but my knowledge of what they are called is bad. I thought what I needed was inner cowl panels, but then i saw rocker panels. Are the rocker panels located on the side of the floor below the door? What I need is the panel that connects to the toe board, and floor pan below the dash on the right side. In other words the bottom front right side. I noticed a listing for two inner cowl panels for a 54. Help. Thanks.
[font size=1" color="#FF0000]LAST EDITED ON Apr-26-01 AT 09:16 AM (CST)[/font][p]The rocker panels are below the door on the outside.Are you needing the floor section or the inner cowl panel?The inner cowl panel is the sheetmetal that your feet kick on the inside.
Craig Hager
[email protected]
The inner cowl is what I need, I saw a listing for two different inner cowel panels for the right side? thanks
