popping noise in floorboard
Discussion in '1967-1972' started by btorear, Apr 1, 2006.
  1. btorear
    btorear Member
    ok new problem. Have a 71 4x4 chevy 3/4 ton. Theres a popping noise I feel in the floor board when turning sharp left. I thought it was the ball joints (and as it turns out one was bad) so I replaced the upper and lower joints on the left side (right side is fine). But the popping noise is still there. It happens mainly when I go over a bump and turn left. its actually more of a bang than a pop, and i can feel it very clearly when it happens. I looked up under the truck this afternoon and it looks like the bushings are worn out on the rear leaf spring king pin. Could this be my problem? Any help would be greatly appreciated.
  2. btorear
    btorear Member
    Found the problem. leaf spring eye bushing. Thanks for NO help in this forum.
  3. kory_kneeland
    kory_kneeland Member
    Salem
    Kory A. Kneeland
    '70 C20
    You know, I hear a similar sound from my truck. The interesting thing is that I have coil springs on my 2wd with a weird half spring helper. I was wondering if it was from the bed moving/tweaking as I turned and bumped. When you say that you "feel" it, do you mean from the floor boards into your feet?
