Power Steering Brackets
Discussion in '1973-1987' started by VRod Scott, Apr 8, 2009.
  1. VRod Scott
    VRod Scott Member
    Need some advice on where to get a Power steering Bracket kit complete with hardware.
    I'm removing my 4.1 V6 in my 83, replacing with (78) 305, MT, NO A/C, stock Exhaust manifolds. Missing all of the power steering brackets. Alternator is on Passenger side, long water pump. There seem to be many options out there, 2 bracket, 3 bracket, aluminum, Etc. Need some recommendations
    1. Who has the best package for mounting for this?
    2. My V6 pump should work, correct?
    Thanks/Scott
  2. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    73-87 with V belt set up. Well there only really one set up that work if you’re using the #1 350 -305 factory none A/c none air pump with power steering.
    #2 305-350 factory power steering With A/c none air pump.
    #3 305-350 factory power steering With A/c with air pump.
