Power window and lock ?
AZ58Cameo
Dec 12, 2008
244
Location
Payson Arizona
Hey Guys,
Kinda new on this side,My Son Has an 85 chevy 3/4T long bed 4x4
I got him two new doors from the Salvage yard $100.00 EA
Both in great shape and they had all the glass and internal parts Minus
door panels and switchs for the windows and power locks,We got what was left of the wire harness,It consists of the plugs for the passenger side and the driver side,we cant seam to find a wiring diagram for his year truck
and can anyone help us?
There are two wires on drivers side I think go to fuse box,
PInk and one orangew/black stripe
then the harness goes up and Y's and the harness was cut at the Y
out of this Y are as follows
2ea black with white stripe
2ea blue
2ea grey
2ea tan
and one Orange w/black stripe
Not sure were all the wires at the Y go to,do they go to the ignition switch?
looked to me when we pulled the harness it was close to the fire wall,do the wires route out the fire wall?to somewere.
Any Help would be Greatly appreciated!
Thanks Allen and Ryan
Just wanted to say also the Truck did not have Power anything and we are trying to convert it over to the power locks and windows and one really big Problem is at the fuse box you cant read anything on the face of it to know were anything goes,we have the doors hung and the cab drilled out and the wiring harness Boots installed an both sides of the cab!Didnt intend for this to be so LONG!!!!!
Thanks again for any Help.
The pink wire is switched (ignition) power for the windows, it should go to the top center connector on the fuse box, right above the fuses. The Orange/black wire is power for the door locks and goes to one of the connectors on the top right side of the fuse box. These are the only connections the harness needs. The "Y" is where the door lock relay connector should be. It mounted on the right side of the steering column bracket. If the dash wiring has been cut, I would just try to find another one with the relay from a junkyard.
Hey, Thank You very Much
We did get the windows to work,My son was able to pull up
a wiring Diagram online and it showed the relay.We need to get
the switches for the door locks as no one has them in our little town
and will go back to the junk yard for the relay.
Thanks again,Allen & Ryan
