progress made on new floors
Discussion in '1947-1954' started by old49chevy, Sep 30, 2009.
  1. old49chevy
    old49chevy Member
    Iowa
    slow going and patch panels suck
  2. ol' chebby
    Looking pretty good. Unfortunately, floors usually include corners, kick panels, the "C" channels in between, and the inner layer where the floor and corners come together.
  3. Zig
    welding...
    That is something I hope to learn how to do someday. Looks like you have it going on! It may be a PITA, but the results look like something that will last for another 70+ years! I can't wait to see how it turns out for you!
  4. ol' chebby
    Zig, mig welding is easy. Get something like the Lincoln Pro Mig 140, grab a few pieces of iron, and try it out. A neighbor found a video on you tube and tried mine out, he actually did pretty well.
  5. Chiro
    Chiro Member
    True that!!!
    I grew up learning how to weld with high amperage/high heat on structural steel beams and such. I was very afraid of the transition to mig welding due to the relatively thin pieces that body panels are, but it truely is easy to learn. Don't be so afraid. Get a welder like Russ says and give it a whirl. By the way your work looks, I am certain you can do it.
    Andy
  6. vwnate1
    Good Work !
    Looking mighty fine there , keep it up and the pix too , you're emboldening many here to give it a try .
  7. Wolf
    Wolf Member
    Kansas
    another one being saved!!! I like it!:D
  8. old49chevy
    old49chevy Member
    Iowa
    almost done!
    I had friday off so I spent all day working on the 49 and got a lot done! I just have a few pin holes to fix under the seat and a lot of dents to pound out then I can start primeing/block sanding. What do you guys think so far? this is the first time that I have ever done body work and welding sheet metal so I am learing a lot.
    Thanks Jesse
  9. vwnate1
    VERY Impressive !
    You're doing a great job , keep it up .
    From junk to jewel .
  10. ccharr
    You are doing great keep up the good work.
  11. Zig
    Just wait 'til you lay the primer on that! First time welding???
    That's outstanding!
    So, are you building it with the six, or going with a V-Nate?
  12. old49chevy
    old49chevy Member
    Iowa
    Zig
    It's going to have the old 216 Babbitt pounder for now.
    Thanks Jesse
  13. vwnate1
    Gasp !
    WOW ! I've not seen a correctly painted & dressed 216 like that in some time . it even has the Carter W-1 carby .
    Very nice indeed .
  14. willardgreen
    willardgreen Member
    Dixieland!
    Thanks for the pictures. You make it look easy. I wish the guy who put a patch panel in mine did as well as you.
    Willard
  15. Zig
    That's BEAUTIFUL!!!
    Jesse~ That is a fantastic job you're doing there! You should have one slick truck when you're all done! And it should last f-o-r-e-v-e-r!:cool:
    Glad to see you're keeping it stock.
  16. old49chevy
    old49chevy Member
    Iowa
    I had some time tonight to work on the 49 so I patched the under side of the dash and the door frame.:D
  17. Wolf
    Wolf Member
    Kansas
    Jesse, thanks for sharing. You have done a lot of work. Looks great too! Keep it up.
