Yes I have a 1962 chevy 1/2ton 4x4 but the body is rusted out and have I a chance to get a 1964 chevy 3/4ton 2wd truck cheap will there be a problem mounting the cabs and front clip on the four wheel drive truck thanks for any info you can give....
The only problem you will have is the front cab body mounts. But since you have the 64 frame, take the two front mounts off the 64 and bolt them to the 62 4x4 frame. Problem solved! The front clip should bolt up with no problems, but if it does post up your ?'s and someone will answer. By the way welcome to the forum!! Jeremy.
