I got this email the other day and I don't know much about the four wheel drive front ends. "I am attempting to remove the front hubs so that I can get to the bearings. I have everything in the hub assembly removed except for the axle sleeve and ring, and the spring retainer plate and the actual hub body. The hub body is loose, however, even after taking off the axle snapring, I cannot seem to budge the axle sleeve and ring gear or the hub body. Is there something that I didn't do that will help me remove the hub body. Please Help. Thank you."
