questions, questions, questions
Discussion in '1960-1966' started by Indeep, Apr 22, 2008.
  1. Indeep
    Indeep Member
    Hi guys I am new to this so I am assuming this is the place to go to get help.
    I am hoping to stand on the shoulders of those who have succeeded in restoring your trucks.
    With that said , I have a basket case of a 66 C-10 that I got from my father in law.
    I have stripped it to the bare bones and I am ready to redo.
    I want to drop it and take out the tired and neglected straight six and add a 383 stroker motor and T-400.
    Is there parts available to mount the motor and tranny or will I have to relocated and fabricate or both.
    your help would be appreciated.
    Thanks
  2. 62 short step
    62 short step Member
    Greenwell Springs, La.
    Welcome!! You can get a tranny crossmember from here, and the motor mounts you can get those aftermarket too. I think Classic Parts might have the motor mounts here too.
  3. 283 man
    283 man Member
    Bentonville,Arkansas
    Welcome to the forum!! lots good folks here glad to help you out.:)
  4. Vin63
    Vin63 Member
    SoCal
    Yep, lots of transmission cross members available. Since you're going with a SBC, the motor mounts are readily available in both tubular form and stamped steel these days. You're smarter than me and not installing a Pontiac. :D
  5. drabo
    drabo Member
    Patrick AFB, Florida
    Since you are starting from scratch did you think about a 700R4 swap. Ask the people in this forum that have done it, it is well worth the money. And with $400.00 a drop gas it will pay for itself.
  6. greg65
    greg65 Member
    DALLAS GA.
    The 700r4 swap is a pretty simple swap. Have your driveshaft shortened,move the crossmember back, and hooked up the linkage. With mine I ordered a painless wiring kit that allows the converter to lock up.
  7. Indeep
    Indeep Member
    Wow!! thanks for the responses. I knew I came to the right place
    When you say the tranny mount is available "HERE".
    Where is here.
    What kind of HP will a 700r4 handle and what are the specs on it.
    Is that a better tranny?
  8. 62 short step
  9. Indeep
    Indeep Member
    Thanks.....I'll start there
  10. Vin63
    Vin63 Member
    SoCal
    The crossmember 62 short step noted in the link is the one I'm using. It's the easiest to mount and position. I'm also running a 700R4 transmission. I'm having it built to handle about 550 bhp and 600 lb-ft of torque. Good luck.
