Quick rocker arm rack question
Discussion in '1947-1954' started by Haasman, Sep 17, 2012.
  1. Haasman
    Haasman Member
    N. CA, south of SF
    Should the bolts that go into the head that hold the rocker arms-
    -have a locknut under the bolt?
    -have locktite on the threads?
    Finally what toque value should I use on these bolts?
    Thanks in advance for replies,
    Haasman
  2. SinclairChevy
    SinclairChevy Member
    Keokuk, Iowa
    There were no lock nuts under the rocker bolts on any of the three 235's that I disassembled in the process of finding one to build up for my project truck. However, I don't know for sure if they're supposed to be there.
    I found this little chart on torque spec's in another forum, NOT from a shop manual. I've used the information for assembling my engine. Use at your discretion.
    main cap bolts 100-110
    bellhousing bolts 45-55
    flywheel bolts 50-65
    rod nuts 35-45
    oil pan corner bolts 12-15
    oil pan bolts 6-7
    clutch pressure plate bolts 25-30
    cylinder head bolts 90-95
    manifold clamp bolts 15-20
    manifold end clamp bolts 25-30
    water pump bolts 25-30
    spark plugs 20-25
    fuel pump bolts 15-20
    rocker shaft bolts 25-30
    Hope this helps.
    Damon
  3. Haasman
    Haasman Member
    N. CA, south of SF
    Thanks Damon
    Haasman
