Radiator cap
Discussion in '1947-1954' started by dorcutt, Jul 9, 2015.
  1. dorcutt
    dorcutt Member
    Keep the truck in VT
    Question for the day. What is the correct radiator cap for my 57 235 in my 51 half ton. I was doing a general inspection on the truck and pulled off the radiator cap and found it all rusted up after only a year. Purchased it from the host here and it's was made in Mexico. I put the old one back on and noticed it said 7 lbs on it while the replacement from Mexico had no markings on it. Searched the treads here and have read where anything over 4 lbs may damage the heater core causing it to leak. So should I go back to the first one that is rusted up or leave the 7 lbs one on that appears to be in better condition? I may try Napa next time for replacement. Dave
    I hope the host pays attention to this forum so the can get a handle on some of there quality issues.
  2. Zig
    I believe I remember reading about that as well. Mine has a 4 pound cap I do believe.
  3. dorcutt
    dorcutt Member
    Thanks Zig
    Is it only rusty on the inside ? might be telling you there's rust deep within the water jacket , a bad thing indeed .
    You can use any Phosphoric Acid based cleaner to soak it and make it look new again , Sno-Bol toilet cleaner for example .
    Read the fine print ! .
    4 # is good as it raises the boiling point of plain water by 3? F for each pound of pressure .
    Add in the coolant mix and you shouldn't ever have any overheating issues .
  5. Thunder54
    Thunder54 Member
    Port Arthur, TX
    4 pounds
    I use the 4 pound radiator cap on my 235.
    I also use the 185 degree thermostat per Nate's instructions.
    Jim
  6. dorcutt
    dorcutt Member
    Thanks all, I will look for a 4 lb cap. I just installed a 160 degree thermostat for the summer, note I have not any overheat issues. Nate should I be worried about rust in the water jacket? The coolant I took out looked pretty green with no real rust color to it. Dave.
  7. vwnate1
    Coolant Care
    Hi Dave ;
    Id there's _any_ rust in it I'd worry .
    For now , just run it hard and hot ~ if the translucent coolant turns murky or red / brown , be aware you'll have to address it seriously and soon .
    Not expensive to do right but takes some time and you must drive it daily until it's 100 % clean then you can relax and make your own 40/60 % mix of distilled water and coolant or just buy the best (Honda , Mercedes , like that) brand of pre mix , change it every 24 months regardless of mileage as RUST NEVER SLEEPS and it can and will , eat holes right through the cylinder block , ruining it :eek: .
  8. dorcutt
    dorcutt Member
    Thanks Nate. I will watch over time. I too have had several British cars (Mg's and Triumphs) so am use to engines that weep a little as the truck does. The electrical is a little better on the truck then the British stuff. Dave
  9. vwnate1
    Oil Weeps & Seeps
    FWIW ;
    I hate oil leaks and I'm now using Permatex " The Right Stuff " because it's AMAZING , unlike any RTV stuff you've ever used before .
    Just use a super tiny thin bead of it instead of or smeared onto , gaskets , button it up and you're good to go .
    Simply amazing stuff and very co$t effective too *if* you're careful .
    I'm using a 5 + year old foo - foo can of it now .
  10. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Nate - Please clarify: flush the radiator and block with phosphoric or citric acid? Thanks.
  11. vwnate1
    Citric Acid Flushing
    Citric Acid powder , one pound per gallon of water , use distilled water and mix it out side ofd the radiator then pour it in and DRIVE it a while .
    I'll usually turn dead black , this is good as it means you're dissolving the rust and scale .Solder bloom goes away too .
    You must first flush out all the old coolant , then drain the system and fill it with the citric acid and distilled water mix .
