Radiator
Discussion in '1960-1966' started by LEYLAND, May 9, 2007.
  1. LEYLAND
    LEYLAND Member
    Ontario, Canada
    Good day, I am installing a 350hp sbc into my 65 short step. I am looking for a replacement rediator as mine in not repairable. I plan on pulling trailers and daily driving and have been told that a "4 core Desert cooler from US radiator" is the way to go.
  2. dvalentine
    That would be your best bet as you are towing. Don't forget a trans cooler if you have an automatic.
    Val
  3. LEYLAND
    LEYLAND Member
    Ontario, Canada
    Thanks Dval,
    is a 4 core radiator really necessary? or can I get away with a 3 core.
    Also is it necessary to use an electric fan or will an engine fan be adequate?
  4. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    A 3 Core Should Get The Job Done, But Remember, If You Spend A Little More Money Now, You Could Be Saving Yourself Alot In The Future. You Dont Need An Electric Fan As Long As Your Using The Fan Housing And A Good Fan, I Prefer A Steel Fan With A Clutch.
  5. dvalentine
    What Kustom said........ ;)
    Val
  6. drabo
    drabo Member
    Patrick AFB, Florida
    Make sure to get a tranny cooler in addition to the one in the radiator especially if you are installing a 700R4.
  7. LEYLAND
    LEYLAND Member
    Ontario, Canada
    Thanks for your help guys. I just ordered a factory replacement 3 core radiator from a supplier in Canada. (its hard to find parts for these trucks in Canada, I'm limited to one supplier unless I want to pay a fortune)
    I will get a fan shroud and good fan...
    Thanks again.
