REAR AXLE
Discussion in '1960-1966' started by 66 KUSTOM, Dec 15, 2005.
  1. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    SHORT STORY, WHEN I WAS GIVEN MY 66 LONGBED, THE PREVIOUSE OWNER CHANGED OUT THE REAREND. HE PUT IN A 12BOLT FROM WHAT I BELIEVE, WAS OUT OF A 60S OR 70S IMPALLA. MY QUESTION IS, IS THIS 12BOLT THE SAME WIDTH (WHEEL MOUNT TO WHEEL MOUNT) AS THE STOCK 66 AXLE? I DONT HAVE THE ORIGANAL TO COMPARE TO.
    THANKS FOR ANY AND ALL HELP.
    66 KUSTOM
  2. drabo
    drabo Member
    Patrick AFB, Florida
    My truck is on stands right now so I'll try to get it measured for you.
  3. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    COOL, THANK VERY MUCH FOR TAKING THE TIME TO MEASURE IT FOR ME!!
    66 KUSTOM
  4. drabo
    drabo Member
    From drum to drum is 57". Sorry it took so long.
  5. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    NO PROBLEM, I APPRICATE YOUR HELP IN MEASURING, ILL GO MEASURE MINE AND SEE WHAT I COME UP WITH.
    THANKS AGAIN!! :)
    66 KUSTOM
  6. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    HEY DRABO, WAS THAT 57 INCHES FROM INSIDE TO INSIDE OF DRUM OR OUTSIDE TO OUTSIDE OF DRUM?
    66 KUSTOM
  7. drabo
    drabo Member
    Inside the backing plate to the other backing plate.
  8. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    COOL, THATS WHAT I FIGURED, I JUST WANTED TO MAKE SURE, MY 12 BOLT IS 56 AND A 1/2 INCHES, (BACKING PLATE TO BACKING PLATE) WIDE SO ILL BE ABLE TO USE THE SAME BACK SPACING FRONT AND REAR.
    THANKS AGAIN DRABO
    66 KUSTOM
  9. chris
    chris Member
    austin texas
    do you know where i can find a posi trak rear axle thanks for the help
  10. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    DEPENDS WHERE YOU LIVE
    66 KUSTOM
  11. chris
    chris Member
    austin texas
    i live in austin texas
  12. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    SORRY, IM NOT ANYWHERE NEAR THERE.
    66 KUSTOM
  13. chris
    chris Member
    austin texas
    do you know where i can find one though ill pay for shipping and how much
  14. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    I WOULD GO TO YOUR LOCAL JUNK YARD AND PULL A 12BOLT OUT OF AN EARLY IMPALLA, SELECT YOUR PREFERENCE OF POSI GEAR RATIOS AND INSTALL THEM INTO THE 12BOLT. YOULL HAVE TO GET A MOUNTING SHOE KIT FROM CHEVY DUTY TO INSTALL THE NEW REAR AXLE. REQUIRES WELDING AND SOME SKILL TO GET YOUR PINION ANGLE CORRECT, PLUS YOULL HAVE TO ADD A BRACKET FOR THE PAN HARD BAR. YOULL END UP WITH A FIVE BOLT WHEEL PATTERN BUT IF YOUR GOING TO CONVERT THE FRONT TO DISC BRAKE YOU CAN CHOOSE TO MATCH THE FIVE ON FIVE BOLT PATTERN SO ALL YOU WHEELS WILL MATCH. OR YOU CAN JUST REPLACE THE AXLES WITH THE SIX BOLT PATTERN AXLES. IT TAKES A LITTLE TIME BUT ITS ALL WORTH IT.
    66 KUSTOM
  15. dvalentine
    Take a look at the Eaton Posi. Summit, Jegs carries them. You will need to match the carrier and your axle spline.
    It should run about $400, which is what it would cost to ship a used one from almost anywhere.
    DVal
  16. drabo
    drabo Member
    Also try Randy's Ring and Pinion. They usually carry the hard to find parts.
  17. chris
    chris Member
    austin texas
    [updated:LAST EDITED ON Jan-13-06 AT 12:12 PM (CST)]thanks for all the help :7
