I finally decided to replace the rear cab mount bushings and in my haste, I broke a bolt on one of the rear mounts. Chevy Duty and others sell the rubber replacements, but who sells the metal parts? Anyone got a used one? or an idea for how to mount the cab using some other method?
I had a similar issue on the rear mounts and found Jim ##### Truck parts was able to find used ones. Also, someone in this forum may have one. Good Luck, Doug
if you were able to remove the broken bolt,you will find taht you can find one repro-or take the unbroken bolt from the other side and go to a reputable fastener shop and I'm sure they can match one up
