Rear End Codes
Discussion in '1960-1966' started by RCF, May 4, 2002.
  1. RCF
    RCF Member
    DeSoto USA
    RCF
    Can someone tell me where I can find the code for the rear end in my '63? All I know is that it's a 12 bolt. I would like to know the ratio. Your help would be appreciated. :)
    RCF
  2. bwiley
    bwiley Member
    Best way to check it out is to just pop the cover on the differential and check the numbers on the ring gear. You will find some numbers (part no?) and then something like 11 41GM . In this case that refers to 11 teeth on the pinion and 41 on the ring gear or a ratio of 3.73 to 1.
    Bruce
