I'm just finishing doing this on a 51. We installed a 95 Impala SS rear and it is a GREAT fit. It has rear disc brakes. You will need to cut off any existing mounts from most any axle as none wil bolt directly up. Order 3" tube saddle mounts from Speedway or Summit. Sit the bracket on the alignment pins, sit the axle on the saddles, center the rear, raise the snout to align pinion angle, then tack weld the saddles. Remove the axle and fully weld the saddles, now re install and ubolt down the axle. Now run brake lines, bleed and drive.
